Utica Boiler Shut Down Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2008, 07:33 AM   #1
Utica Boiler shut down problem
Have a Utica steam gas fed bolier that shuts down every so often and wont kick back in with a call for heat. The quick fix that always used to work would be to cycle the power on and off to the entire system. This seemed to always get the call for heat going. The low water cut off is operating as well as all electrical controls (transformer etc..) Can't figure this out.
Any help/advise appreciated
halo is offline   Reply With Quote
Old 02-29-2008, 03:03 AM   #2
Have you tested the thermostat?
redline is offline   Reply With Quote
Old 02-29-2008, 07:41 PM   #3
biggles's Avatar
first you should check(tighten)any and all electrical terminals both on the power side and the controls up into the stat if it is not consistantly happening(certain time but random) might be a loose connection...something is bouncing.shut the boiler off and flush your low water limit might have mineral buildup or garbage inside it... here's their site might get something off it http://www.uticaboilers.com/
utica boiler ignites for 5 sec. then shuts off UBoiler HVAC 17 07-21-2008 09:40 AM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 11:49 AM
Utica Boiler Pilot light on but will not flame up! MGB150HID HVAC 2 12-10-2007 04:48 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
