Utica Boiler Model 200 Agb Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 10:23 PM   #1
Utica boiler model 200 agb help
I am trying to help a friend with a problem on his utica boiler as I have a little experience working on boilers and furnaces (but I am no expert). Unfortunately, I can't find a manual on this model to even see how it is supposed to work. We think it is from the early 1980s.
He replaced the pilot light thermocouple, as he has a few times in the past. He can relight the pilot and it will stay lit. He turns the gas valve on and the main burners will ignite for about thirty seconds and then everything goes out - burners and pilot light.
Anyone have any ideas for differential diagnosis? Does this model have a flame sensor for the main burners that could be shutting it off? Does this sound like an exhaust issue?
He's had the unit since he owned the house - many years - and this is the first time its done this.
nhkrugb is offline   Reply With Quote
Old 03-23-2011, 06:25 AM   #2
hillbilly guru
Send a message via Yahoo to hvacguytn615
are there any safetys on this unit. if you can post some pics or give a little moer info on the wireing .
hvacguytn615 is offline   Reply With Quote
Old 03-23-2011, 07:17 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
if the pilot goes out as well as the main burner, and you have already replaced the t-couple. I would lean towards a bad gas valve. You can test the t-couple output and the drop out mV on the gas valve with a t-couple y-99 adapter. Also make sure there is no accessory limit inline with the t-couple. Make sure t-couple is correctly immersed in the flame. Make sure t-couple is properly seated in the Gas Valve.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-23-2011, 10:54 AM   #4
Thanks - problem appears to be solved
He swapped in another brand new thermocouple, ensured the positioning was good in the flame, and cleaned off the burners. It fired up successfully. I do appreciate the feedback!!
Utica MGB75HID boiler wont start need to know HVAC 5 11-27-2010 07:55 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
utica boiler won't start massman Plumbing 0 01-23-2010 06:26 PM
Problem with Utica boiler starting billygeg HVAC 3 01-04-2010 08:07 PM
utica boiler ignites for 5 sec. then shuts off UBoiler HVAC 17 07-21-2008 09:40 AM
