Old 11-04-2011, 01:50 PM   #1
USING A TH8321U1006 HONEY WELL THERMOSTAT WITH A HEAT PUMP WITH GAs as the back up
why will option 350 not work when i set it for the gas to cut on when outside temp gets to below 35 it cuts on when it drops below 45
harold noah is offline   Reply With Quote
Old 11-04-2011, 05:37 PM   #2
How is the White wire from the heat pump wired? Did you leave it disconnected? If you have the white wire from the heat pump connected then it will turn on the furnace when the HP goes into defrost mode which could be fooling you, this will heat up the coils and may damage the system. If this is the case, disconnect the white wire from the HP.
I have the exact same thermostat and 350 works just fine for me.
-Jeff
zootjeff is offline   Reply With Quote
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Wiring New Thermostat for Heat Pump AND Boiler Sweetpea_cmb HVAC 3 10-28-2010 02:29 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
