Using Old Linesets With Different Refrigerant - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 10:09 PM   #1
using old linesets with different refrigerant
i do a lot of changeouts and some time people have finished basements that cover the lines. if they are the right size can i run r410a thru line sets that were used for r22. i know the manufacturer says not to use it because the different oils, but will it work this could save some time.
bandbsheetmetal is offline   Reply With Quote
Old 01-07-2013, 10:16 PM   #2
Rewards Points: 582
they make flush kits for that purpose...the small amount of oil left after flushing won't hurt a thing....but its always best to replace if you can......also they make r-22 dry units for replacements...ben sr....as a side thougth we always purge with nitrogen first to make the flush kit work better...
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
bandbsheetmetal (01-07-2013), carmon (01-07-2013), hvactech126 (01-08-2013)
Old 01-08-2013, 12:05 AM   #3
Rewards Points: 616
purge nitrogen behind the flush kit is my method....done many that way... so far they all survived..... I do agree100% to change lines when possible.....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
ben's plumbing (01-08-2013)
Old 01-08-2013, 05:56 AM   #4
An old Tradesmen
Rewards Points: 6,476
I just blow out the lines with nitro.
The Following User Says Thank You to beenthere For This Useful Post:
Vibration in refrigerant supply line slickwilliam HVAC 6 05-20-2012 10:37 PM
King valve as expansion valve... Danman5000 HVAC 14 09-18-2011 12:18 PM
Temperature at Refrigerant line too low? crakarjax HVAC 23 01-15-2011 03:20 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
new ac unit leaking refrigerant foxsam HVAC 16 12-15-2009 01:53 PM
