-   -   using old linesets with different refrigerant (http://www.diychatroom.com/f17/using-old-linesets-different-refrigerant-168525/)
bandbsheetmetal 01-07-2013 09:09 PM
i do a lot of changeouts and some time people have finished basements that cover the lines. if they are the right size can i run r410a thru line sets that were used for r22. i know the manufacturer says not to use it because the different oils, but will it work this could save some time.
ben's plumbing 01-07-2013 09:16 PM
they make flush kits for that purpose...the small amount of oil left after flushing won't hurt a thing....but its always best to replace if you can......also they make r-22 dry units for replacements...ben sr....as a side thougth we always purge with nitrogen first to make the flush kit work better...
carmon 01-07-2013 11:05 PM
purge nitrogen behind the flush kit is my method....done many that way... so far they all survived..... I do agree100% to change lines when possible.....
beenthere 01-08-2013 04:56 AM
I just blow out the lines with nitro.
