Using Insulated Fiber Board To Construct Plenum? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 05:22 PM   #1
Rewards Points: 242
Using insulated fiber board to construct plenum?
I am fighting with a tough install. Just very tight with things in the way. A friend mentioned use of insulated fiber board to construct the entire plenum from scratch. I did not know that would fly but apparently does???
Are there any concerns using this product? Is it pricey or tough to use? I have construction and machinist experience but never worked with this product. I envision something similar to mineral wool sheets with Al backing.
viper is offline   Reply With Quote
Old 09-08-2010, 06:26 PM   #2
fabrk8r
fabrk8r's Avatar
It flies by code, but personally I would use metal. I don't like the way duct board tends to fall apart over time.
To me metal is easier to work with, and looks better, but then again I've had a lot of practice.
If you don't feel comfortable making a plenum you can have one made fairly inexpensively at your local sheet metal shop. Just get some accurate dimensions.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-08-2010, 06:38 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
And take pics to shown them. Making up sheet metal plenums etc leaves a lot to be imagined for in line drawings. Especially if there is an offset.
Old 09-08-2010, 06:41 PM   #4
Rewards Points: 242
No problem with the design. I design aerospace parts and have a 3D model of the one I need right now. The issue was just that I am sure something will not fit exactly right due to the area it is going and I wanted it insulated anyway to reduce noise so the fiber board was kind of a catch all.
What would a guy spend for one that is say 19x21 at the coil and converging to 14x21 and a height of 3ft? I have talked with a couple locals and indicate a 200 build. Now, I do A LOT of Al sheet metal and if my brake could do this, I would be making it from Al.
I am just spit balling on costs. Obviously that is hard to estimate without the print..
Is that fiber board very expensive? I hear there is a "special" cutter that will cut a 90* notch out where you want to bend. Sounds kind of slickbut never tried it..
Old 09-08-2010, 07:04 PM   #5
HVAC / Plumbing
If you have a brake, build it yourself. Are you going to insulate inside or out or both ?
kenmac is offline   Reply With Quote
Old 09-09-2010, 02:47 PM   #6
fabrk8r
fabrk8r's Avatar
An insulated transition that size would be about $50.00 and take about 15 minutes if I used the plasma table. It would take 3/4 hour if I had to lay it out and cut it by hand...that would be close to $100.00
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
wet fiber board on troch down roof meharm1957 Building & Construction 1 06-11-2010 12:45 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Insulated plaster board John Ryan Green Home Improvement 1 12-16-2008 09:11 AM
Fiber board duct & humidifier BigD HVAC 1 12-26-2007 06:04 AM
