Old 10-03-2011, 06:59 PM   #1
using furnace fan to distribute heat from fireplace
Normally I am heating my house with a heatilator fireplace. The basement is cold though. I want to set the furnace thermostat to 70 F. and when the room with the fireplace, which also has the furnace thermostat, reaches 70 F. I want the furnace fan to come on but no heat from the furnace. When I am not going to be home for an extended period in the winter I want to flip a switch and have the furnace work normally to prevent the house from freezing in the winter. The current thermostat is a mercury switch with only 2 wires going to it. No switches at all except the one for the temperature. The return air also happens to be near the fireplace.
What should I do?
Wayne
waj8 is offline   Reply With Quote
Old 10-03-2011, 07:31 PM   #2
An old Tradesmen
Run new thermostat wires. Then get an auto change over thermostat. Wire it in. Set the cooling temp to 73, and the heating temp to 70. Then when the room temp reaches 73 the fan will come on, when it drops to 70, the furnace will take over.
Old 10-04-2011, 01:04 AM   #3
Thank you. I will probably set it to 60 for heat and 70 for cooling. I see the two wires are hooked up to 2 of the 5 screws on the control box of the furnace. The screws are labelled with letters. Do I just match the letters on the thermostat with the letters on the control box? Do I use 5 conductor wire?
Wayne
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Leaking Heat Exchanger in Furnace - Heat On Brentimus HVAC 1 03-19-2011 10:42 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
dDistributing heat from a fireplace insert. hoosick falls HVAC 5 11-13-2010 08:21 PM
