Using Condenser Motor As Blower.. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 08:51 AM   #1
Using Condenser motor as blower..
Hello folks,
I have a small emergency cos my blower motor packed up.
I have a spare condenser motor with the exact same ratings etc..
Can I use it for a day or so, until I get my hands on a replacement blower motor?
Thanks in advance
duxsi is offline   Reply With Quote
Old 06-19-2011, 08:56 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
I doubt it. Your furnace motor is 110 volts and that motor is 220 volts. Unless you have a 220 volt airhandler. RPMs will be different and wiring to the motor from the capacitor.
Old 06-19-2011, 09:01 AM   #3
They're both 208-230V, 1/3 HP, same RPM's, the same ampere..
It would be for about 24 hrs, until I get a new Blower motor.
Would the condenser motor run too hot?
Bad idea?
Thanks.
Old 06-19-2011, 09:26 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
It may run too hot as it is designed for wide open/unobstructed continuos air over it to cool itself (fan motors have slots/vents in them and a cooling fan to allow air in for cooling) and may have a different design rating/motor duty and service factor (technical motor design details). May have a different diameter/frame size. I would not try it/go thru all that trouble.
Old 06-19-2011, 09:30 AM   #5
Thanks for your response.
Appreciate you taking the time..
Old 06-19-2011, 09:44 AM   #6
biggles's Avatar
once it starts the RA will cool it has to be lower then 85 air thru a condenser and up into your face +10F...run it check it after first cycle hand on body and let it ride....just couldn't do it the other way most AHUs are open types not seale as the condenser one is
Old 06-19-2011, 09:55 AM   #7
Sorry Biggles, you lost me..
Could you please clarify.
Old 06-19-2011, 09:59 AM   #8
Yes it will work for a temp fix.
Old 06-19-2011, 10:00 AM   #9
Just got it.. Thanks
Old 06-19-2011, 10:02 AM   #10
I'm Your Huckleberry
Rewards Points: 2,270
No, it wll not work for long, It is a design of torque thing, why the motors say condenser on them or I think they do.
It has to do with open air flow versus a blower wheel which is enclosed, the pitch of the blades and the amount of air.
Doc Holliday is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Condenser and Blower not turning on nEmEsIs15dead HVAC 11 08-09-2010 09:56 PM
trol a temp mastertrol. Thermostat cannot kick on blower and condenser Ben2010 HVAC 0 07-25-2010 09:01 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
