Using Baseboard Hot Water In A Radiant Floor?? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 08:48 AM   #1
Rewards Points: 256
Using baseboard hot water in a radiant floor??
Is it possible, or useful/efficient, to use the looped hot water in the baseboard system to flow through radiant heat tubes in some portion of the house? We are thinking of installing a new cork plank floor in the living room, which is near the end of the heating loop for our single story house in Connecticut, and I am wondering if, instead of buying a separate system, I can simply reroute the returning existing hot water through new tubing under our floor, then back to the furnace? Is that ever done? Thanks.
tpagel is offline   Reply With Quote
Old 03-08-2008, 09:26 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
The radiant needs its own loop. The water temperature for radiant is between 80-130F depending on how close the tubing is to the surface of the floor. The water temperature out of the boiler fluctuates between 150-180.
You can use the same boiler but you need mixing valves to lower the temperature to the floor. I could go into more detail but this answers your question of if you can just tap into the existing lines.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 03-08-2008, 11:26 AM   #3
Rewards Points: 256
Is this an expensive undertaking, or require a lot of room for equipment? Sounds like if the basic infrastructure is in place, the majority of the costs have already been incurred, no? Any idea of a square footage cost for about such a loop for a 300-400 SF area? Thanks very much in advance for your reply!
Old 03-08-2008, 07:38 PM   #4
in my area of canada radiant for piping is in the area of 4 to 6 bucks a square foot installed
billie_t is offline   Reply With Quote
Old 03-08-2008, 08:06 PM   #5
I have gas!
Is this work you're going to contract out or DIY?
Radiant is basically the most expensive heat you can install.
Old 03-10-2008, 09:33 AM   #6
Joe F's Avatar
Rewards Points: 294
Take a look at the second option in this link. Is it a valid option?
http://www.radiantdesigninstitute.com/page64.html
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Water damage below laminate floor ediconu Flooring 10 01-23-2012 01:19 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
elec. floor radiant or hydronic ??? James Con HVAC 1 10-16-2007 07:36 AM
basement floor water bigboyjoel Building & Construction 1 05-21-2007 05:46 PM
