Using A 4 Ton A Coil With A 5ton Outside Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 02:54 AM   #1
Using a 4 ton A coil with a 5ton outside unit
I have 4 ton Goodman ac unit that is on it,s last legs. I have a 5 ton Trane unit without a matching A coil. Can I use the 4 ton Goodman A coil with the 5 ton unit?If so what precautions must be observed?
Big Cellie is offline   Reply With Quote
Old 12-15-2011, 04:23 AM   #2
An old Tradesmen
Rewards Points: 7,380
No. And you air handler probably can't move enough air for 5 tons of A/C. Good chance the 5 tons will be too big for your house also, and cause humidity issues.
Old 12-15-2011, 08:06 AM   #3
I have a 5 ton blower on the furnace, blower was damaged in shipping and the only replacement available was one removed from a returned 5 ton setup
Old 12-15-2011, 08:14 AM   #4
HVAC Tech/Owner
Rewards Points: 604
what exactly do you have??? What furnace...AC...Coil...What is the right size for the house??? What's new? The furnace? AC? What are you matching?
Technow is offline   Reply With Quote
Old 12-15-2011, 09:19 AM   #5
The Furnace is 100k BTU and ok for house, the Trane unit is 3 years old was removed from a place where building was being revamped, furnace keps place comfortable and bills are reasonable. 2 summers ago I had to install a hrad start on the ac compressor. I got the 5 ton unit for a very resonable price, however the A coil got away.
Old 12-15-2011, 10:06 AM   #6
HVAC Tech/Owner
Rewards Points: 604
Sorry, don't believe it....All of these system components should be matched with the house and with each other... It's like "I got a great deal on a 454 chevy big block engine...why doesn't it work with my Honda civic???? I got 30mpg with the civic, but with the new 454 engine I am only gettin' 10mpg???
...but i turn the stat off at night and in the morning I crank it up to 70 from 55 degrees and it gets there within 10 minutes, must be working good ...
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Condensor and Coil replacement ? sin360 HVAC 2 07-22-2010 11:31 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 05:39 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
