Urgent!--Can You Put More Freon In An A/C Condensor Than The "factory Charge" Amount? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 07:15 AM   #16
Rewards Points: 1,214
I believe most units with a factory charge are good up to 15' of line set after that the amount changes. Once you get the right amount as previously stated then you tweak it in on the super and sub.
COLDIRON is offline   Reply With Quote
Old 07-28-2011, 01:04 PM   #17
Originally Posted by beenthere View Post
The only time a system would have more put in it then the factory listed charge is. Is when the system has no refrigerant in it, the line set is longer the the factory's precharge amount allows for, and or an evap coil that is larger then the most common match is used/being used.
On a system that still has some charge in it, generally the amount added won't be more then the factory's listed charge.
Thank you. I don't think those other conditions applied in this case.
Heatwave is offline   Reply With Quote
Old 07-28-2011, 01:07 PM   #18
Originally Posted by REP View Post
No No No now listen to me.Each SYSTEM has a correct charge that depends on numerous things that the guy in the factory know nothing about,but each system has a need for a corect amount of gas to do the job.To determine that amount you take a super heat calculation and/or a sub cooling calculation. THIS IS THE "ONLY"WAY TO DO IT RIGHT!!!!
This is a little confusing. I was talking about freon, not gas. Also, I just wanted to know what the case is generally. I question whether it is routine for a serviceman to put more in than the factory charge (unless fraud is the norm). They said they put three in a 4 lbs 5 oz charge and I am beginning to question whether they even put that much based on what the poster said about the table.
Old 07-28-2011, 01:22 PM   #19
Rewards Points: 6,652
Freon is a gas. The serviceman should know how much charge, if they know what they are doing. Only way there is fraud, is when you end up with some guy that does not know what they are doing, and does not honor the contractual agreement to make sure the work they perform is as stated, whether verbal or written on paper.
Old 07-28-2011, 01:23 PM   #20
JJboy's Avatar
You have to trust only a hvac technician that used Digital refrigerant scale, when he said, he added 2 pounds refrigerant. Otherwise He is guessing.
The SH and SC will determine if he need add or remove refrigerant.
Refrigerant = Freon = Gas ( in this post )
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
