10-21-2011, 02:41 PM
#1
Upstairs...HOT in summer, cold in winter
It seems my real big issue is not enough air conditioning or heat comes out upstairs in which makes it cold in the winter and hot in the summer. It feels great downstairs though. My house was built before it was required to have two units for a two floor house. I cant afford another unit so i need some other options. Any ideas?!?!
10-21-2011, 03:53 PM
#2
Average Joe/ex-Navy IC3
No insulation, leaking windows, poor duct design to begin with. Can be a number of factors why the house is not working with the hvac system as it should.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
10-21-2011, 07:50 PM
#3
Well if you put your hand in front of the vent when the heat or air is coming out it is a dramatic difference from upstairs and downstairs. You can hardly feel it upstairs.
10-21-2011, 09:27 PM
#4
That does not mean anything. If you can not feel it upstairs, you need to contact a hvac company or tech to come and look at the system to find out why. If anything, you may be better off placing a system on the second floor, just to serve that space.
10-21-2011, 09:31 PM
#5
I'm Your Huckleberry
Where's the inside furnace located, basement? Hard pipe or flex?
Take pics.
10-22-2011, 04:35 PM
#6
Take pics.
It is located in the attic and the duct work is the round flex type. I'll try to get some pics in a min.
10-22-2011, 04:49 PM
#7
starve the 1st floor and make the second as the first floor was. with adjustments seal the discharge fles any place it is leaking..check the discharge duct on the furnace 360 all the way around it....take it you have ceiling return up on the second back to the furnace in the attic.the air should be the most closest o the furnace you have it backwards the duct dampers are starving the 2nd flr..where is the stat
10-23-2011, 08:16 AM
#8
Sounds like you need to have the flex replaced they cause restrictions in the air flow. If you run the blower in the "on" position that will help with the air circulation and make sure any and all filters/coils is clean and do you know how many CFMs you are moving and the size of the unit? you should be moving 400 CFM per ton.
10-23-2011, 08:50 AM
#9
do you have a return grill on the first floor that rises up into the attic or are the stairs the return
10-23-2011, 08:59 AM
#10
I have the same problem to only 1 room upstairs. It has 1 duct fed by a flex line and it gets minimal air flow. Changing that would be expensive due to tearing out walls, etc...
Do you think a duct booster fan would help?
10-23-2011, 09:54 AM
#11
JOE......did you try to cheat down on the other supplies that are doing bigtime air...the unit only puts out a certain CFM it might be to difussed to make it to that one room if its at the end of the supply run forget it...might want to retap it nearer the air handler so you don't need to ripe a wall and are all the connection tight with no air leakage
10-23-2011, 10:28 AM
#12
I'll check on the unit size but how do I check the CFM's?
10-23-2011, 10:29 AM
#13
Yes I do have one on the first and the second floor.
10-23-2011, 10:56 AM
#14
You will need a manometer to check the CFMs you should be able to rent one. look on you model # for the size, if you dont know post the number and we will tell you the size.
10-23-2011, 09:10 PM
#15
This is the model number.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
