Upstairs Cooling Problems - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-15-2011, 04:19 PM   #31
An old Tradesmen
Rewards Points: 6,886
A wall cavity, or build a small chase and run a single trunk line in the chase. And then run the branch supplies to the rooms. probably work better that way.
Old 07-15-2011, 04:54 PM   #32
So basically run a large (16") duct up my wall cavity and then into a distribution box, cut holes in the ceilings and run ducts to them?
enielsen is offline   Reply With Quote
Old 07-15-2011, 05:06 PM   #33
An old Tradesmen
Yep, round or rectangular duct up to teh attic. And then the branches as you said.
Old 07-15-2011, 06:54 PM   #34
So how do I know what size of flex duct to use when I branch off?
Old 07-15-2011, 08:21 PM   #35
An old Tradesmen
Without doing a room by room load calc. Look what size the floor register is fed with. then use the next size bigger.
Old 07-15-2011, 08:37 PM   #36
So probably 8 inch. How much do you think it would cost to do this and how hard do you think it would be for somewhat of a beginner.
Old 07-15-2011, 08:39 PM   #37
An old Tradesmen
Don't know what it will cost you. I get my material at whole sale cost. You'll pay retail.
If you take your time, you shouldn't really have an y problems.
Tags
insulation
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 07:39 PM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 03:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
