Old 11-05-2010, 09:17 PM   #16
Just call me Andrew
Upstairs baseboards not getting hot
I was looking at the wrong side of the gauge...it's ~30PSI.
Is it worth putting monoflo tees on the returns from the baseboards (faced in the proper direction of course)?
Andrew
secutanudu is online now   Reply With Quote
Old 11-06-2010, 03:30 AM   #17
An old Tradesmen
If you also put a way/method to remove air from the base boards. It is.
Old 11-06-2010, 09:18 AM   #18
Just call me Andrew
There is about 8 inches of exposed pipe in a closet upstairs...I could probably sweat in a bleeder valve. How would I do that? Just put on a tee? What does the bleeder look like?
Andrew
Old 11-06-2010, 10:13 AM   #19
An old Tradesmen
You would want to use a purge valve if your just installing on the return line.
Make sure you don't already have something like these
Already on your baseboards.
Old 11-06-2010, 11:15 AM   #20
Just call me Andrew
The exposed section of pipe is kind of in the middle of the line. Could I install something like your second picture upstairs in the closet? All the pipes upstairs are at the same height.
Andrew
Old 11-06-2010, 11:30 AM   #21
An old Tradesmen
Is it one continuous straight pipe from each baseboard to the next. With no elbows?
hen you could. but it would take a long time to bleed the air. The purge valve is much easier to use to get rid of air.
You probably already have a method. Your just not recognizing it. They had to be able to get teh air out when they originally installed it.
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 12:25 PM
To turn off the upstairs AC or not Big Dawg HVAC 18 08-11-2010 07:15 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 05:01 PM
HVAC Upstairs QUESTION Statecowboy HVAC 1 09-15-2007 12:15 PM
