Upgrading To Modern Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 08:07 AM   #16
Originally Posted by biggles
if you have a solid state module in the furnace those wires out of the wall connect to letered termials...R,G,Y,W,C on the board
Thanks Biggles. Not sure what you mean by a solid state module.
Would you disconnect the current thermostat from that "connector" that connects the wires from the unit into the old thermostat?
I notice the wires from the wall don't have any orange but it now has a blue wire and a white with green stripe.
jeremydpenn is offline   Reply With Quote
Old 07-07-2012, 08:09 AM   #17
So your system is a fan/coil unit that connects to the buildings heating/cooling water system. I'm not familiar with those, so will let others help you with this. Sorry for any confusion.
Any chance one of those tenants would let you peek at the wiring configuration? That would save a lot of time ...
scottmcd9999 is offline   Reply With Quote
Old 07-07-2012, 08:17 AM   #18
Rewards Points: 494
Describe how you get heat and A/C. Ceiling registers for cooling? Baseboard for heat or forced air for heat also?
Do you have a utility closet with a door with louvers ?
diyorpay is offline   Reply With Quote
Old 07-07-2012, 09:51 AM   #19
Forced hot air
Old 07-07-2012, 10:10 AM   #20
biggles's Avatar
down in the furnace there might be a control module on the supply fan housing or in front of the burner section with resistors,and terminals on it the stat wires land there and correspond to the lettering up into the stat subbase on the wall....just throwing out stuff for you to add to others we'll get you going like this with terminals only one within it http://www.bestbuyheatingandaircondi...ode=CIB0110074
Tags
electrical , hvac , nest , thermostat
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
