Upgrading Furnace And AC - HVAC - DIY Chatroom Home Improvement Forum
Old 05-20-2008, 10:22 AM   #1
Rewards Points: 212
upgrading furnace and AC
We have a 20yr old natural gas furnace (Lennox) and AC (also Lennox). It was described as mid efficiency when purchased with house from builder in '88. It has conventional chimney.
I intend to request suppliers to provide some quotes for replacement. This request is to get some pertinent info as to what exactly I should be asking.
I'd like to replace with high efficiency gas (90+%), and the associated "plastic vents"/chimney. I do have a rental HW tank (gas) that I'll continue to have, but not sure how HW chimney would fit in all of this)
My thinking is for supplier to include costs for
*new furnace
(I'd like air filter; humidity controller;--anything else here?)
*programmable thermostat
*variable speed high efficiency fan/blower (ECM motor for fan)
*new AC
*removal of old furnace and AC
*new chimney/vents
*connection for any water/humidity overflow from AC
*connection for any water from condensing heat exchanger
*warranty period (preferably 10 yr)
I look forward to comments and experiences that could be used in my request.
Anyone have suggestions/comments?
Thanks in advance.
orange is offline   Reply With Quote
Old 07-19-2008, 09:36 AM   #2
Knucklez's Avatar
Rewards Points: 932
sometimes people will install furnace and AC at two different times for financial reasons. if this is so, install the furnace first and at that time ask them to also install the coil for the AC (this part goes in the air duct in furnace for cooling).
and get one quote for the entire job (furnace & ac) but ask them to delay payment of ac until that job is done a year later.
Knucklez
Knucklez is offline   Reply With Quote
Old 07-19-2008, 07:03 PM   #3
Furd's Avatar
If you have made any energy efficiency improvements on the house such as increased insulation, weatherstripping or new windows be sure to request the supplier do a complete heat loss / heat gain calculation.
Request a two-stage furnace.
Request a ductwork evaluation, including any necessary sealing and insulation of ductwork.
Request the thermostat have full seven-day programmability, has two stages of heating and has an "adaptive recovery" subroutine.
Furd is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Furnace not firing jax HVAC 5 02-22-2009 12:41 PM
Upgrading wall furnace Wanttodoitright HVAC 2 03-20-2008 05:57 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
