Upgrade RV Analog With Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 03:20 PM   #1
Upgrade RV analog with Honeywell Thermostat
I want to upgrade my analog thermostat to a Honeywell RTH230B in My travel trailer This is the wiring for the Honeywell...
RH...heating power supply
RC...cooling power supply
W....heating power supply (I assume W= white)
Y....cooling signal (I assume Y = yellow)
G...fan (I assume G = green)
This is the wiring for the Duo-Therm...
Green....GND
Blue...hi fan
Brown...fan
Red... 7.5 (I assume this is voltage)
White...heat
Yellow...cool
I don't need low fan capability. I keep mine in the auto setting.
Could you please tell me how to wire the Honeywell. I am not very keen on electrical stuff like this and would sure appreciate some help.
Ray Wallace is offline   Reply With Quote
Old 08-12-2009, 08:09 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Green....GND
Blue...hi fan
Brown...fan
White...heat
Yellow...cool
I'll take a stab at it
Jump RH/RC and pur the red wire there
White wire to W
Yellow wire to Y
Blue wire to G
Tape off green and brown wire.
Again I am guessing here. Never worked on a travel trailer
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-12-2009, 09:12 PM   #3
biggles's Avatar
plumbers got it.....only thing i will add is see if the subbase on the new stat calls for a C wire connection.that would be the other side of the transformer within the furnace,the newer electronic stats need a solid 24Vs constant at the subbase to support the board on the stat(if you see no C your good to go just check the fan cycle thru the heat call so you know its there come FALL
Old 08-13-2009, 01:34 PM   #4
Appreciate the help. I will try installing it tomorrow and let you know how it works.
I don't understand this comment...".only thing i will add is see if the subbase on the new stat calls for a C wire connection.that would be the other side of the transformer within the furnace,the newer electronic stats need a solid 24Vs constant at the subbase to support the board on the stat(if you see no C your good to go"
The Honeywell board is power by two aa batteries. I don't see a C anywhere on the thermostat.
Again thanks a million for you kind help.
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
