Upgrade HoneyWell Chronotherm III To Venstar 2491T7E - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 04:52 PM   #1
Upgrade HoneyWell Chronotherm III to Venstar 2491T7E
Hi all,
I recently purchased a 6 wire Venstar 2491T7E w/Integrated Insteon to replace an old HoneyWell Chronotherm III. The chronotherm has 8 wires, and the Venstar only has 6. It doesn't look like all of the wires are necessary....one appears to be for a Status LED marked (L).
Is it possible for me to make this upgrade work, or do I need to buy a different Thermostat?
mustangnc1 is offline   Reply With Quote
Old 08-26-2012, 06:14 AM   #2
An old Tradesmen
Rewards Points: 6,072
Do you have a link to the install manual.
Old 08-26-2012, 10:25 AM   #3
Houston204's Avatar
Rewards Points: 556
What terminals are used on the old stat?
If the old stat was controlling a heat pump with electric heat strips, the new stat will need more than a W1/O/B terminal. It will also need an Aux/W2 terminal.
An E terminal is also an indication that it is for multistage heat pumps.
As Been has posted an install manual link would be of great assistance. All that I see online are homeowners manuals with no diagrams or terminal listings. It looks like the new stat does not have Aux or E terminals on other posts. Is this listed on the package?
Houston204 is offline   Reply With Quote
Tags
chronotherm , honeywell , insteon , venstar
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 08:41 AM
Honeywell Q674L to RTH7600D upgrade ssn HVAC 2 10-06-2010 07:53 PM
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 04:20 PM
Upgrade RV analog with Honeywell Thermostat Ray Wallace HVAC 3 08-13-2009 01:34 PM
Honeywell T8600D Chronotherm installation sasquatchbreath HVAC 9 11-02-2006 04:15 PM
