Update On Coleman Furnace Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 12:57 PM   #1
Thumbs up
Update on Coleman furnace won't shut off
I wanted to thank Yuri and Beenthere for replying to my post a couple weeks ago. The electric company was very helpful and came out and put a recorder on for about ten days. There is something going on but the engineer is a little puzzled as to just what it is exactly. He thinks that one side of the 220 is fluctuating and the other is stable. They are coming out again and doing some sort of test at the meter to see if it is on their side. I'm thinking that if it's on my side then perhaps its where the two sides of the double wide are connected, perhaps one of the connections is getting some corrosion. Meantime I'm turning my furnace off when I leave the house and using the space heater as I don't trust the furnace. My heating guy sent another invoice and wants no more to do with trying to figure out what is taking out the sequencers.
Chipappa is offline   Reply With Quote
Old 03-08-2013, 01:15 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
Glad to hear you are narrowing down the problem. I understand your htg guys frustration as I have been there many many times.
If you suspect some poor electrical connections at the double wide joint you may want to get that checked ASAP as poor connections create heat and fires and can be VERY dangerous.
Old 03-08-2013, 04:09 PM   #3
An old Tradesmen
Rewards Points: 6,540
Glad to hear the power company is staying on it, and not giving you a brush off.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Coleman furnace problems IUFAN87 HVAC 36 01-04-2012 08:56 AM
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 07:51 PM
Trane furnace runs even after burners shut off smb2 HVAC 3 01-10-2010 09:16 AM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
