Unusual Noise From Light Fixture - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 10:36 AM   #1
Unusual noise from light fixture
Hello, I have an unusual noise when AC is on. Sounds like dishes tapping each other. Slight sing song effect. Very low. Wife can't hear. I have extremely sensitive hearing. I have narrowed it down to a track light on a very high cathedral ceiling (about 30 ft up). The track light rail is about 6 ft long, has 3 canned lights. The unusual thing is the sound is only there when lights are off. If I turn lights on, the noise stops.
I don't believe there is a ballast to the lights.
The noise is slow coming on and going off.
I believe the heat generated by the lights have some effect on the noise. Like perhaps there is a loose bulb and as the heat causes the metal to expand, the noise is stopped and as the lights are turned off, the noise starts.
Any suggestions as to how I should start troubleshooting this problem.
The fixture is so high I won't go that high so I will have to hire someone to help me.
Any suggestions? Thanks.
Bill
poston8 is offline   Reply With Quote
Old 03-19-2012, 04:20 PM   #2
Get a long pole even if you have to rig something up. Touch the bulbs one at a time when you hear the noise and try to isolate it. Could it just be a loose bulb? HD sells those light bulb changers on a pole that would help if you need to tighten or change the bulb.
mpnret is offline   Reply With Quote
The Following 2 Users Say Thank You to mpnret For This Useful Post:
beenthere (03-19-2012), poston8 (03-19-2012)
Old 03-19-2012, 04:43 PM   #3
mpnret
Thanks for your reply. I'll try your suggestion.
Old 03-19-2012, 04:50 PM   #4
Your suggestion worked.
It was a loose blub. thanks very much. You saved me money and irritation.
using light fixture to power 40" lcd tv? hoszor Electrical 3 07-21-2011 10:20 AM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 09:26 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
