Unused Rooms....Should I Close The Vents Or Leave Them Open - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 05:51 AM   #1
Unused rooms....Should I close the vents or leave them open
I have a two story house. I do not use the upstairs at all. There are 4 rooms up there.. Should i close the room vents? Close the vents and doors?? Close the doors and open the vents?? Should I open the vents. Open them just a little bit???............ If I ask 10 HVAC guys, 5 will say open / 5 will say close???. Any thoughts out there??
simagic is offline   Reply With Quote
Old 05-15-2014, 06:07 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Leave them open.
You can control flow if there is a damper at the main supply trunk but that will affect all the distribution on that line.
I would leave them open and just close them slightly if you would like to.
Old 05-15-2014, 06:13 AM   #3
There "is" a damper at the main supply trunk that supplies the upstairs. Well, that would lead me to asking ,,, should I close the that main damper that controls the upstairs air
Old 05-15-2014, 06:29 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
this is more of an hvac question, but my to my understanding, by closing some rooms off you are throwing off the balance of the system and causing it to operate less efficiently.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
simagic (05-15-2014)
Old 05-15-2014, 07:32 AM   #5
Rewards Points: 1,538
I say close the vents of the rooms you are not using --- but with some stipulations:
1. Before closing too many (say more than one out of five) you need to reduce the system fan speed. See the system instructions; this typically requires re-arranging of a few wires on screw terminals.
2. You also need to close the return vents in the affected rooms but you need enough return vents still open for the system to operate properly.
3. What stays open should be at least half of the vents fully open (mid-duct damper also fully open), or the equivalent.
Old 05-15-2014, 08:45 AM   #6
Rewards Points: 736
Move into a smaller house.
TheBobmanNH is offline   Reply With Quote
Old 05-16-2014, 06:14 PM   #7
I have a similar question, since my wife believes that closing the doors of unused bedrooms will somehow conserve heat (we have a gas-fired hot air system) or cooled air. I believe this is a waste of time and, in fact, it reduces the necessary air flow in the house by preventing enough air from making it back to the returns.
Perhaps a professional could weigh in on this. Thanks.
longislander2 is offline   Reply With Quote
Old 05-16-2014, 08:44 PM   #8
Rewards Points: 469
Air conditioning needs 350-400 cfm of air moving across the a coil and your heat needs enough air flow to keep the temperature rise from going to high. If this is a old system that has duct work over sized you will be okay, If it is sized correctly you will not be running the a/c at its designed flow, And the temp rise on heat may be to high
The dampers in the basement are for adjusting airflow in the house to balance it
Jnaas2 is offline   Reply With Quote
Old 05-17-2014, 12:09 AM   #9
I'm Your Huckleberry
Rewards Points: 2,270
one system for whole house? Zoned or not?
I'd leave all vents open and leave doors to all rooms upstairs open fully.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-17-2014, 09:53 AM   #10
Rewards Points: 1,192
Close them and see if anything bad happens.
bobelectric is offline   Reply With Quote
Proper way to leave unused wire in wall psuryan Electrical 3 10-26-2010 08:16 PM
Bathroom perimeter joints: just leave 1/4" open on perimeter if wood trim will hide? lazzlazz Tiling, ceramics, marble 0 04-23-2010 03:01 PM
Close Heat Vent on Unused Room? Lilac HVAC 2 01-06-2010 12:55 PM
What to leave open for inspection? forkvoid Remodeling 21 02-14-2009 09:58 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 01:39 PM
