Unlabelled W And R, Will The World Explode? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 11:57 PM   #1
dtc
Unlabelled W and R, will the world explode?
I'm replacing an old thermostat (manual) which has 2 wires connecting to the heater. Unfortunately, there doesn't seem to be a label on the old thermostat, or the wires.
Questions:
1. Can I assume these two wires are R and W?
2. What would happen if I connected them backwards into my new thermostat (a honeywell RTH700D). Will that cause any damage?
3. If getting this wrong will cause damage, how can I go about determining which one is R and W? (Ideally without accessing the furnace, the door to it is blocked right now by a bunch of other stuff.)
Thanks!
dtc is offline   Reply With Quote
Old 10-11-2009, 05:06 AM   #2
biggles's Avatar
R is always RED (hot 24Vs),and W is always WHITE (heat)......you could put the wires together and call the furnace in.if the stat isn't digital and is a generic printed dial face with temps and you set the temp bar ...go for it.if your digital then the RED has to be connected to R on the subbase. you should make a project and clear that stuff from the furnace access...you might not want to do it,but if the system breaks down,and a service guy comes in charging you $100 HR to check it out on a nice 10F night it would be to your benny
Old 10-11-2009, 06:30 AM   #3
An old Tradesmen
Rewards Points: 6,876
Is your new stat battery operated?
Old 10-11-2009, 10:08 AM   #4
May also need to check the air filter.
SKIP4661 is offline   Reply With Quote
Old 10-11-2009, 10:55 AM   #5
I imagine Beenthere is asking if the system is battery operated is because you need to have a "common" for t-stats that are not battery powered. If you only have two wires coming from the wall, and have no intention of running new wires, you need to have a battery powered stat if you plan on going with programable or digital.
In short, the house will not "blow up" if you reverse the connections. One lead is hot, and the other lead is the heating circuit. A t-stat is simply a switch that senses temperature.Installing a heat only stat is simple, but, you should turn off the power to the heating appliance first. Otherwise you could short out the low voltage circuit.
Flashheatingand is offline   Reply With Quote
Old 10-11-2009, 11:29 AM   #6
dtc
Thanks guys. My new thermostat is battery powered and has a computer that claims to think on its own (I expect to eventually become its servant.)
The old one was mercury free - uses a coil.
I was wondering if I could assume that the two wires connecting to the coil were "R" and "W", and was wondering what the consequences would be if I connected "W" to the "R" terminal of the battery powered one, and "R" to the "W" terminal since the wires aren't labeled.
Old 10-11-2009, 03:24 PM   #7
An old Tradesmen
None.
Old 10-11-2009, 03:30 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
You know Max?
Old 10-11-2009, 03:50 PM   #9
An old Tradesmen
Originally Posted by yuri View Post
You know Max?
Old 10-11-2009, 03:52 PM   #10
Hvac Pro
yuri's Avatar
Max no difference.
Old 10-11-2009, 04:01 PM   #11
GC/Master Plumber/Mech
Rewards Points: 560
Yuri went a fish'n and Been took the bait
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-11-2009, 04:02 PM   #12
An old Tradesmen
Max no difference.
ROFL.
ZOOM went right over my head.
Old 10-11-2009, 04:05 PM   #13
An old Tradesmen
Hook line and sinker.
What is the best paint in the world? Majid Painting 30 06-23-2012 12:28 PM
If Women Controlled The World.... gma2rjc Off Topic 8 04-13-2009 01:51 PM
ICI - Glidden - Color Your World nzan Painting 1 02-27-2008 06:03 PM
World of Wheels Video - Chicago 2007 head_dunce Automotive Repairs 0 01-30-2007 07:49 AM
