Unit Is Trying To Heat In Cooling Mode... - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 11:00 PM   #1
unit is trying to heat in cooling mode...
I have a comfortmaker, built in 95. it is really hot in our house at almost 90... when i try to get it to come on manually, by switching tstat to "on" position, nothing happens. When I turn off power to unit (inside unit), and then back on, sometimes the light flashed 5 times, other times it will only flash once then off. If i turn on and off a few times, then it will try to start, and sometimes does, at least the blower motor. My biggest question... why does it call for cool and then go into heat mode?? currently, all i can get... the blower motor blowing continously.
Thanks for any help!
gotdirtygrout is offline   Reply With Quote
Old 07-11-2008, 10:00 PM   #2
Rewards Points: 150
while i am not off the top of my head fimiliar with the led diagnostic code it is most likely labled on the schmatic to me it sounds like a control board issue and would be worth it to get a pro with boots on the ground but if you can determin that it is the board that info would be helpful so the tech can come prepared
geo fan is offline   Reply With Quote
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 7 01-15-2011 07:39 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 06:59 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
AC Unit Continuously Runs - yet it is cooling reefland HVAC 4 06-17-2007 07:04 PM
