Unhappy - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2014, 07:35 PM   #1
Angry
unhappy
I'm having a problem that i've never encountered with my Trane heat pump outside unit
slyshot is offline   Reply With Quote
Old 07-25-2014, 07:41 PM   #2
kwikfishron's Avatar
Rewards Points: 344
I'll move this to the HVAC forum for you.
Do you have a specific question?
kwikfishron is offline   Reply With Quote
Old 07-25-2014, 07:41 PM   #3
Ok, I'll bite, and what problem are you having?
jmon is offline   Reply With Quote
Old 07-25-2014, 07:47 PM   #4
unhappy
I came home from the dr. today only for my wife to inform me that my Trane outside unit was making a noise
Old 07-25-2014, 07:49 PM   #5
What kind of noise?
Old 07-25-2014, 07:50 PM   #6
I thought the fan was hitting something but after removing the side cover,I saw the points chattering on the 24 volt coil
Old 07-25-2014, 07:59 PM   #7
unhappy
I breifly held those points in,at that time I also heard the coil on the reverseing valve making a noise also,otherwise the unit works fine ,I turned it on to cool the house a couple of times,luckily its dowm around 60 here now
Old 07-25-2014, 08:22 PM   #8
has anyone seen a unit still working with this kind of electrical problem?
Old 07-25-2014, 09:02 PM   #9
Welcome to the forum slyshot.
You have 5 posts now, you should be able to post some pics of your trane with the cover off so the hvac techs can look at what you have. Thanks.
Click on post reply, scroll down to manage attachments, upload and post your pics from there.
Old 07-26-2014, 05:35 AM   #10
An old Tradesmen
Rewards Points: 6,824
If the contactor is chattering, and left to continue. It will cause the compressor and fan to die an early death.
Trace out cause of low voltage problem and correct it.
The Following User Says Thank You to beenthere For This Useful Post:
jmon (07-26-2014)
New home construction - So unhappy with tile/grout colors Robert95z Flooring 16 11-03-2012 03:19 PM
very unhappy h/o because of DIY neighbor Blossom Off Topic 13 07-14-2010 12:12 PM
unhappy..nobody responded to my Help question bullipapu Roofing/Siding 4 08-14-2009 05:12 PM
very unhappy with the job my deck builder did - Q's dtran Building & Construction 17 06-08-2008 12:43 PM
