Uneven Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 06:47 PM   #16
Dr Heat's Avatar
I still use toilet paper
I have two alinars (SP?) but they are usually a in a truck with one of our techs a cigarette works too AH the good old days
Dr Heat is offline   Reply With Quote
Old 01-19-2009, 07:27 PM   #17
JohnH1's Avatar
Originally Posted by hvaclover View Post
OK smart ass you know I wa just giving the HO a step by step if he want to do it him self.
My self, I use the tried and try Bacarach volometer along with Delta T measurments.
I got a few of my own rules of thumb I have used over the years. Im sure I will let some slip out here and there. I know I know sometimes paybacks are a b****.
Lets see here one. Stand on the curb across the street from the house you want to install A/C in. Then hold your hand out 2 feet in front of your nose then start holding up 1 finger at a time untill the house is covered. 1 2 3 4 The house needs a 4 ton A/C. NOT!
JohnH1 is offline   Reply With Quote
Old 01-19-2009, 07:51 PM   #18
There is a service bulletin on that sizing technique. seems it's been recalled for recalibration cause it was designed by a guy with only four fingers.
hvaclover is offline   Reply With Quote
Old 01-19-2009, 07:54 PM   #19
JohnH1's Avatar
Now that funny!!
Old 01-21-2009, 08:26 AM   #20
Geek for Hire
Rasputin's Avatar
Minor update:
Turned out the 2 returns on the 1st floor were already sealed so I removed the cardboard/duct tape 'sealing' and I'm getting some more velocity from the vents.
I also recaulked the front double window in the living room, the master bath window and 1 master bedroom window. I'll have time to get to the second window tonight. Also weathersealed the electric box in the master bath with that DAP vinyl foam stuff since it was on an outside wall.
Temp is now more stable but still colder than the south side.
And man, caulking the top of a window is hard when you're barely 5'5 and have nothing to stand on.
Rasputin is offline   Reply With Quote
Old 01-21-2009, 08:39 AM   #21
Originally Posted by Rasputin View Post
Minor update:
South Jersey? You must be Italian.
Old 01-21-2009, 08:48 AM   #22
Geek for Hire
Rasputin's Avatar
Mostly Irish and Italian, originally from Brooklyn. Moved down here for college and never left.
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
