-   -   Undertile Heating Installation (http://www.diychatroom.com/f17/undertile-heating-installation-28367/)
DIYKerfuffle 04-18-2005 01:53 PM
I want to install an undertile heating system in my kitchen. The sub-floor is concrete. Do I need to lay tile backerboards first? Wickes (Idea 80) recommend that a tile backerboard is used, as the concrete will result in downward heat loss. However, some websites don't seem to mention this disadvantage of concrete. Should or shouldn't I use tile backerboard? If so, is it expensive?
dirkgently 04-19-2005 12:31 PM
Use backboard you will regret it otherwise.
DIYKerfuffle 06-05-2005 12:18 PM
Thanks.
I used thermal insulation boards, which have the same thermal properties as construction boards such as Wedi, but without the expense!
