Understanding Hvac... Cold Air Return Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 07:08 AM   #1
Rewards Points: 29
understanding hvac... cold air return questions
I have some work to do and one of the jobs is to shorten the cold air return... moving it shorter will eliminate one of the vents in the end.. If I do that, do I have to add a vent somewhere to make up for the I'm eliminating? The guy from hvac company that put system in came out and said its a easy quick job but it going to cost 500$...
Shawnzy is offline   Reply With Quote
Old 09-05-2012, 07:36 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
What size system do you have, what size is the main return/ the existing duct run and what is the size of the remaining return grill?
I ask because you need a minimum amount of return air per ton. It could be that the one you are removing was simply an addition to the minimum, or it could be one part of the two that equals the minimum. You can never have too much return air, you can install return airs all over your house if you wanted from just that one system, but you can have too little.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-05-2012, 10:28 AM   #3
biggles's Avatar
do all the rooms have their own R/A vents eliminating one of 2 in a room will effect the room return but minmal on the system,with the other R/As pulling the difference...do you have a main area R/A vent near the stat
Old 09-05-2012, 07:25 PM   #4
Without being there to measure air my answer is going to be yes. Nobody spends extra money to install duct that doesn't need to be there so if you remove one then replace it.
Return air / cold air draft BIG1RED9 HVAC 0 12-11-2011 09:38 PM
HVAC return in basement stringers HVAC 0 11-18-2011 03:14 PM
Help with hvac return duct gasbie HVAC 3 06-19-2011 11:44 AM
Basement Return Questions 108Stitches HVAC 5 02-03-2009 11:56 AM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 09:42 AM
