Old 05-09-2011, 08:39 PM   #1
undersized and oversized
what is the effect of undersized and oversize compressor, condenser, and evaporator..
Farzeem Khan is offline   Reply With Quote
Old 05-09-2011, 08:45 PM   #2
Hvac Pro
Why do you want to know. There are 12-24 different problems with those and you need to understand the fundamentals of refrigeration to understand them.
Old 05-09-2011, 09:39 PM   #3
An old Tradesmen
Thats a bigger question then you realize.
Can you n arrow down the question to what your application is.
Old 05-09-2011, 09:51 PM   #4
Wire Chewer
Red Squirrel's Avatar
undersized: will run forever and take very long to cool - inefficient
oversized: will not run long enough, stop right away, only to start again shortly after. So lot of on/off cycles. Also inefficient. Will also never give the coil a chance to collect much water, so the humidity control won't be very good.
I'm sure there is more to it too but that's the jist of it.
I learned about the oversizing factor with my 1 ton AC unit I use in a 70 square foot room.
Red Squirrel is online now   Reply With Quote
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
Undersized evaporator coil peterk HVAC 4 05-05-2010 06:22 PM
Reducing BTU's tedhermitage HVAC 11 10-28-2009 06:55 PM
boiler undersized? or oversized drdon51 HVAC 27 01-15-2009 01:52 PM
