Underground Natural Gas Line - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 08:51 PM   #1
Rewards Points: 113
underground natural gas line
I recently got an estimate from a HVAC company to run gas line to shop. From the meter, he would run 3/4" black pipe attached to side of house above footing for 30 ft., go into ground 20" with 3/4" copper and run it 125 feet, exit with 3/4" with black pipe up side of shop 8 ft, then into shop 18" with a cut off valve. A total of 167 feet.
First, I thought $10 per foot was on the high side, but now as I look deeper into the requirements, I don't think he would be to code with the 3/4" copper pipe----he said that he was a certified pipe fitter.
Anyone have any idea about the cost of the yellow poly pipe that is available for gas?
Captflx is offline   Reply With Quote
Old 05-17-2009, 09:04 PM   #2
HVAC / Plumbing
Copper would be to code... The size will depend on length & the pressure on the pipe & the total BTU of appliances.There are sizing charts in the code book.. He should be able to give you a price n the poly pipe , fittings & the risers that will be needed... If you go with poly . I suggest that you have him install a tracer wire
kenmac is offline   Reply With Quote
Old 05-17-2009, 09:23 PM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 802
In my state you need to be a licensed plumber to do gas lines. Or the homeowner. If it's above ground, I can file the permit as an exempt contractor, and if the town ok's it, I can do it. But the town has say-so.
Copper can be a bad idea for natural gas, depending on how clean or dirty it is. Plus the joint from steel to copper can be a problem. Around here if it's going in the ground, it's either steel pipe with factory applied coating, or fused polyethylene with tracer wire and warning tape.
Being a certified pipe fitter is only as meaningful as the regulating body that certifies him.
Also, the town should have ultimate say on type of pipe. Size would also need to be calculated, not guessed at.
The PE pipe is less expensive and easy if you have the right tools and are factory trained.
But check with the town and make sure a licensed plumber isn't required.
Aggie67 is offline   Reply With Quote
Old 05-17-2009, 09:37 PM   #4
HVAC / Plumbing
Like you said about copper. It depends on the nat gas in your area.. It can cause scale to form inside the copper.. In my area there are thousands of houses piped totally with copper. Making the connection from steel to copper isn't a problem . You just use a brass fitting from pipe thread to sae thread.. Here if you are a plumber .You also have to be certified gas fitter to run gas.. All depends on area what is / isn't required
Old 05-17-2009, 10:23 PM   #5
An old Tradesmen
Rewards Points: 6,068
Hope its only a 20,000 BTU appliance, with that length.
Or else a med, or high pressure gas line.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (12-27-2012)
Old 05-18-2009, 08:31 AM   #6
Rewards Points: 113
Actually, the heater is 30,000 BTU input with 80% eff. output. Higher pressure needed?
Old 05-18-2009, 09:38 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Beenthere must have looked it up in the sizing tables 4U. Personally I would use 1" otherwise you will need higher pressure and another stepdown pressure regulator at the shop. If the copper gets any bit of a kink it will reduce in size and if scaling is a problem then it is not recommended. With 1" you have some safety margin and room for expansion later.
The Following User Says Thank You to yuri For This Useful Post:
Old 05-18-2009, 12:23 PM   #8
An old Tradesmen
" cooper gas a 45,000 BTU rating at 175'.
How ever, that doesn't allow for the bends, or any roller coaster area of the copper.
1" is much better if your gas pressure is less then ".
Old 05-18-2009, 01:14 PM   #9
Rewards Points: 113
OHHHHHH. I see a big bill coming up if I have to go to a 1" line!
Thanks to all for your input.
Old 05-18-2009, 05:35 PM   #10
sktn77a's Avatar
Rewards Points: 360
My non-professional opinion is to stay away from the poly lines. Oh, sure, they seem good now, but that's what they said about poly waterlines 20 years ago. Anybody in the HVAC business for some time will also remember the grey Hart and Cooley PVC furnace vent pipes which had to be replaced with externally vented, dual wall, metal pipes.
Let someone else be the guinea pig for the pipe manufacturers!
sktn77a is offline   Reply With Quote
Old 05-18-2009, 09:31 PM   #11
HVAC / Plumbing
Most gas utilities in my area have been using this http://www.teecoproducts.com/catalog/F1.htm For years..
Old 05-18-2009, 09:38 PM   #12
HVAC / Plumbing
Don't know what kind of 3/4 copper he intends to use.. The 3/4 black pipe will be 3/4 I. D. The copper could be 3/4 O.D.which would be 1/2 I. D. Just depends on the copper he uses
Old 06-11-2010, 02:19 PM   #13
In my state [New Jersey] you need to be a licensed plumber to do gas lines. Or the homeowner. If it's above ground, I can file the permit as an exempt contractor, and if the town ok's it, I can do it. But the town has say-so.
Late post, just to clarify some things said in this thread in case others use it for reference.
Correction note: In New Jersey, any person can install gas pipe. No license, certification or otherwise is needed.
But to connect the piping to the gas source (such as gas company meter), or to connect any gas appliance (such as furnace, water heater, stove, etc.) to the piping, you need to be a Licensed Master Plumber, or be the home owner.
Also, using plain black pipe outside is not recommended because it will rust. Either coat the pipe after installation with galvanized paint, or using galvanized piping instead of black. Painting will most likely be cheaper, but you need to make sure every bit of the black pipe is completely coated with the paint.
There is absolutely nothing wrong with poly gas pipe. Short of a manufacturer defect, it is the best way to go. Currently it is estimated to last 100 years in some brands.
The water pipe issue was due to the chlorine added to the water "eating away" at the plastic water pipe causing a toxic mixture in the water. Gas lines do not have chlorine and only small amounts of water, so this is not an issue.
DonCorneo is offline   Reply With Quote
Old 12-27-2012, 01:26 PM   #14
Rewards Points: 88
from zoro.com it is cheap also available from amazon.com
G1054855 Underground Natural and LP Gas Tubing and Fittings Gas Tubing, Yellow, 1.05 In OD, 150 Ft $101.40
the problem are the darn fittings. I spent a few hours trying to get them. continental makes some and there are other companies as well. hard as hell trying to find someone locally or online that sells t hem.
$24 for a coupler, $45 for a male adapter, $24 for coupling tool. I've got $175 in adapters just to connect this pipe from one end to the other!
rollandelliott is offline   Reply With Quote
Old 12-28-2012, 08:29 AM   #15
REP
When did poly come into gas puiping.I retired 10 years ago and before that I use flexable stainless with a yellow poly coating.The gas never saw the ploy,it was just a coating like electrical insulation on coppeer wire.The Stainless is better than black iron or copper as far as strength and lasting ability goes.
REP is offline   Reply With Quote
Underground Electrical Line and water line. Randell Tarin Electrical 11 09-18-2011 09:19 AM
New Underground Gas Line steve f Plumbing 20 03-04-2011 09:15 PM
PVC line on natural gas line for BBQ Nikroo Plumbing 28 05-13-2009 10:01 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
Underground Hot Water Line st940692 Plumbing 15 10-15-2008 02:04 PM
