#1 |
under floor hydronic heat
Hello,
I would like to add some extra heat to the rooms over a crawl space approx 500square feet. The bedrooms and hallway(350SF) are hardwood and the laundry and 1/2 bath (150SF)are tile. The thermostat is in a hallway and is set at 70F. The crawlspace walls are insulated. The rooms off of the hall are usually 65-67 when the hall is 70. The wood floors are 62-65 and the tile is COLD. I have baseboard heat with the water set at 180F. I would like to add a zone to heat the floors from below. I understand if I attach the PEX to the underside of the floor I will need to cool the water to 120ish with a mixing valve so I dont damage the wood floor. I am thinking of running the PEX on the bottom of the floor joist so I dont have to fight looping it around and wont have to add a mixing valve and hopefully I can keep the temp at 180 with no damage to the floors. Any ideas?? Thanks |
| Display Modes | |
| dual fuel heat pump - no heat without propane | sweetfarm | HVAC | 3 | 10-11-2012 09:07 AM |
| Heat Pump Thermostat HELP!!! | MichaelG | HVAC | 22 | 12-09-2010 05:50 PM |
| VisionPRO Setup Functions & Heat Pump | infoskr | HVAC | 31 | 03-18-2010 02:15 PM |
| Comparison and Heat Pump Selection help... | ChrisDIY | HVAC | 7 | 03-06-2010 09:34 PM |
| Heat Pump Woes | Zenica | HVAC | 50 | 01-27-2009 08:37 AM |
