Under The Cabinet Ducktwork - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 11:42 AM   #1
under the cabinet ducktwork
I'm in the process of redoing kitchen- one of my HVAC forced air/heat register is behind where one of my base cabinets will go (we are going to try and relocate it)- If not - where do I purchase (or have made) some type or ductwork that attaches to the existing register (I think it's like 6" x 8")- to a small, narrow duct to run out the toe kick? My other option was to buy one of those electric toe kick heaters but then I have no solution for the AC in the summer?? thoughts?
skinut2234 is offline   Reply With Quote
Old 09-19-2012, 01:16 PM   #2
If you are a little bit handy, with some metal sheet you can build a closed or a U shaped (make is easier to screw to the floor) duct and attach it to the register, I did it once. Is not pretty, but once the cabinet are on, is not visible.
Pirulo is offline   Reply With Quote
Old 09-19-2012, 06:45 PM   #3
Rewards Points: 13,732
Simpler to just make it out of plywood.
Old 09-19-2012, 07:32 PM   #4
I probably did not do it the right way but I ended up using a flexible duct, routed in the 4" tall empty cavity under the cabinet.
allthumbsdiy is offline   Reply With Quote
Old 09-19-2012, 08:26 PM   #5
Building code requires that the entire warm part of a heating system be enclosed in metal sheet, even when is probably safe to use some plywood at the very end of the system.
Old 09-20-2012, 12:35 AM   #6
That is not good, the nylon pipe is going to slow the flow of the air, and it looks terrible. Use rigid metal pipe, or even better, use a metal box, I installed hundred of those (I hated to do it, because I installed them when the cabinet where already on place, it's a very unpleasant job to access that small space, so low on the floor), google for "toe kick vent".
Old 09-20-2012, 01:37 PM   #7
Nylon duct is only 30" long, fully extended, so I am going to guess minimal amount of air flow resistance.
With the duct work being offset in relation to toe kick vent, I just could not get the hard ducts to work without multiple turns, possibly creating leaks.
Here is the finished picture:
Old 09-20-2012, 03:44 PM   #8
From the outside that looks really good. About the duct work, now it's done, but you can use rigid metal elbows, that you can adjust the angle from 0 to 90 degrees and put 2 or 3 in your case.
Old 09-21-2012, 01:55 PM   #9
OP, You may want to look into this kit (http://www.toekickductor.com/shop.html). I don't think it is much different than what I have done, but it does provide you with some adapters.
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
