Unclogging HVAC Line At The Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 12:02 PM   #1
tam
Unclogging HVAC line at the plenum
OK, I'm new at this, but am trying to avoid a call to the AC guy that my husband thinks I should make. Our upstairs AC line appears to be clogged between the plenum and the drain. The water is dripping into the overflow. We ran a snake into the drain at the overflow, and that section is not clogged. Can we safely access the drain at the plenum and unclog this ourselves without damaging the plenum or drain? A quick response would be great, or I have to call for service! Thanks.
tam is offline   Reply With Quote
Old 05-04-2009, 04:21 PM   #2
You can use compressed air from the inside drain access at the plenum to force out the clog. Or you can configure a wetvac to vacuum from the outside drain access. You could also try the wetvac from the drain access at the plenum as well.
mjbxx is offline   Reply With Quote
Old 05-04-2009, 05:17 PM   #3
tam
What do you mean by "inside" when you reference the "inside drain access?" And how complicatede is it to open the drain access at the plenum?
Old 05-05-2009, 04:10 PM   #4
Door
There should be a big panel with screws, unscrew it and look in where the drain goes in and clean away any dirt or debris blocking the drain line pour water in there to be sure its unclogged or go downstairs where the drain line ends and try back blowing air back wards to free up the clog.
SULTINI is offline   Reply With Quote
Old 05-05-2009, 05:48 PM   #5
biggles's Avatar
if you remove the panels on both sides of the fan you should be inview of the condenseate pan under the evap coil.where the plastic white condensate line comes out ids the blocked point....reach in to the pan area and you should be able to wiggle your index finger in the outlet hole.take a old piece of garden hose with a wet rag wrapped on the end of it put it over the hole and and blow on the other end.cycle some water into the pan to flush the trap out.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 12:40 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Drain line for HVAC gray6411 HVAC 1 05-26-2008 01:03 PM
Plenum Design winkydink HVAC 1 11-22-2006 10:28 PM
