Unable To Start/bleed Beckett Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 07:20 AM   #1
Unable to start/bleed Beckett furnace
I have read through a lot of information on how to bleed a furnace that had run out of oil. But I am still not having any luck. When I open the bleeder valve, I just get a very slow drip of oil. I am unable to get the furnace electrically started. I have tried tapping the reset button, holding the reset button a long time, thermostat on and off, burner emergency switch on and off. What is it supposed to sound like when it's on but not primed? What else can I try to get it running again? As far as I know, there is nothing wrong with the furnace--it just ran out of oil.
Elkridge is offline   Reply With Quote
Old 01-16-2013, 09:45 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... The oil feed is bled, with the burner motor Runnin'....
If it don't start with a single push of the burner control reset button,...
Something is Very wrong, electrically...
If ya don't know How to test electrical components,...
I suggest you call a burner service Tech, as yer in over yer head...
Is there a reset button on the Motor,..??
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
