Unable To Run Test Sequence On Payne Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 10:46 AM   #1
Rewards Points: 16
Unable to run test sequence on Payne Furnace
Furnace stopped working. Upon checking noticed the igniter had cracked, so replaced with an OEM igniter. When I restarted the furnace the blower motor started, ran and stopped. The LED indicator light just blinks rapidly indicating the 115 line voltage polarity is reversed. I have not even touched the line voltage. Used a tester and polarity was correct. Then I reversed anyway just to see if that would correct the problem. It did not, so changed back to the way it was originally.
eweneek1 is offline   Reply With Quote
Old 10-23-2012, 04:38 PM   #2
More often than not a false error code means the control board is bad.
Old 10-23-2012, 07:20 PM   #3
Rewards Points: 582
I agree with marty....sounds like a bad control board when you get an error code that makes no sense..and changing ignitor would not do that...
Old 10-23-2012, 08:10 PM   #4
Rewards Points: 616
yep....think the board lost it's noodle...
carmon is offline   Reply With Quote
Old 10-24-2012, 02:21 PM   #5
Rewards Points: 16
Unable to run test sequence Payne Furnace
Anyway to test the circuit board? Replaced the board 1/25/04.
Old 10-24-2012, 06:21 PM   #6
You already tested it by switching polarity and still got the same error. They can't be rebuilt so buy another.
The Following User Says Thank You to Marty S. For This Useful Post:
ben's plumbing (10-24-2012)
Old 10-24-2012, 08:19 PM   #7
Rewards Points: 16
Thanks Marty. Will look for a used circuit board. Will be installing a new system in a couple of months.
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Payne Furnace Pains - Updraft/downdraft parts swap?? sticknca HVAC 1 12-12-2011 08:11 PM
Inducer motor replacement on a payne furnace exintrovert HVAC 6 07-02-2010 07:07 PM
payne furnace inducer motor minime_moomey HVAC 13 02-20-2010 12:52 PM
Burner won't fire on Payne 490AAV furnace lwhpops HVAC 2 10-20-2006 03:03 PM
