Old 10-17-2007, 10:47 AM   #1
UN-Comfortmaker RPJ2
Hello, Does anyone know what problems the comfortmaker RPJ2 could be having if it seems everthing is working and yet the burners won't fire up. The moter turns on , the igniter glows for 5-10 secs but no fire/heat. I am having a new baby soon and really want to get it fixed but not spend a lot of money "troubleshooting" with my dollars. Any and all help is welcome and it will keep my mother-in-law from harassing me when she comes in two weeks!
camcdole is offline   Reply With Quote
Old 10-17-2007, 11:31 AM   #2
Is the gas shut off at the valve or the gas line? If gas is on, are you getting 24 volts at the gas valve?
cjett is offline   Reply With Quote
Old 10-17-2007, 11:45 AM   #3
The gas is on; the on/off valvue is located about three feet down from the unit along the pipeline. I do not know if I am getting 24 volts because I don't have a meter(maybe I can get one later). In anyccase , even though this is going to seem dumb, the igniter gets pretty bright and stays on for a while(5-10 secs.). Another thing is that I don't hear a gas "hissing" noise when it comes on. Maybe I am missing it over the motor noise but I think I should hear or smell somthing! Right?
Old 10-17-2007, 12:21 PM   #4
Usually when the gas valve receives the 24 volts you will hear a "clink" or some such sound when the valve opens and a lot of times you can hear the gas. You might not smell the gas because of the draft motor pulling it out of the combustion chamber. Without a meter to confirm voltage at the valve there is no way to be positive, but I would think the valve is defective and needs to be replaced.
Old 10-17-2007, 03:34 PM   #5
Unhappy
Thanks. I think I hear a clicking sound but I'm not quite sure. I may afterall have to call a pro to look at it. Thanks for all the help, I do appreciate it. At least I tried to "DIY"!
Old 10-17-2007, 03:36 PM   #6
Hey you guys wouldn't happen to know how much that part is do you?
Old 10-27-2007, 10:07 AM   #7
joatmon
Post
this may be a bit late but just noticed your post of problem ur havin with comfortmaker. i was havin a simlr prob w my furnace. the furnace wud light for about 5 seconds then go off(continously). finally traced the source of the prob. the nipple on the exhaust blower fan where the vac hose frm the pressure switch connects was clogged with deposits of some sort. cleaned it out and the furnace works great! hope you got it fix in time b4 mother-in-law arrives/d
quintetvsop is offline   Reply With Quote
More On This Topic
Hey again Don Golden for Expert Village and we are working on copper piping. One of he essential ingredients is fire. Fire baby, got it right here in the can. This is the mat gas that we all know and love. It is like propane only a little bit hotter... Read More »
Hi! My name is Grace Fitzpatrick and I am here on behalf of Expert Village and I am going to talk to you today about making a noise at the same time you spray your cat. You want to make a noise when spraying your cat because that way if you don't happen... Read More »
Signs of Hearing Loss
Signs of Hearing Loss by Expert Village
There are several ways that you can recognize that you are starting to develop a hearing loss. With hearing loss it does happen in most cases very gradually, so it tends to sneak up on some people, but there are some tell tale signs. Perhaps the most... Read More »
Full-service gas stations are a thing of the past. You can't tell whether your tires need air by looking at them or even by kicking them. It's up to you to check and add air to your tires monthly. Read More »
Hi my name is Elizabeth Cantu on behalf of Expert Village. We are talking about sugar gliders and some of the noises these guys make. One thing I wanted people to know about these guys is that they are nocturnal and one of the ways they look for... Read More »
Comfortmaker furnace won't turn on steelframe8459 HVAC 31 02-08-2009 08:38 AM
Comfortmaker furnace problem dragon2125@hotmail.com HVAC 2 12-07-2008 02:12 PM
Comfortmaker RPJ2 rusty55125 HVAC 4 04-03-2007 10:27 PM
Comfortmaker RPJ2 won't ignite tyear8299 HVAC 1 03-05-2006 05:06 PM
Comfortmaker RPJ2 rusty55125 HVAC 5 01-02-2006 04:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
