Ultra V Tech 80 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 06:59 PM   #1
ultra V tech 80 furnace
the burners light when the thermostat wants heat, but they go out before the fan comes on. The burners will come on 4 or 5 times and go out, then the furnace turns off. It will do the same thing if I turn the thermostat off and then on again. Even if the fan switch on the thermostat is on, rather than on the auto setting, it does the same thing.
licarlton is offline   Reply With Quote
Old 01-17-2012, 08:15 PM   #2
on the face of it i would say the sensor needs cleaning. but it could be something else too. clean the sensor and see if that clears the problem.
hvac5646 is offline   Reply With Quote
Old 01-17-2012, 08:18 PM   #3
Rewards Points: 582
yes agree with hvac5646 clean sensor 1st also make sure filters are clean something we all forget to do????
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Armstrong Air Ultra V Tech 80 problem... wont stay on :( Kassy HVAC 12 11-10-2012 06:09 PM
tiling under new furnace gramps416 Flooring 4 01-09-2011 10:47 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
