UBERHAUS TH-3200 Programmable Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 06:30 PM   #1
Hi there!
We replaced a programmable thermostat with the UberHaus TH-3200 and now my furnace doesn't come on period!
I have a pilot light, the switch is turned on and my bill is paid so I know it isn't any of those things.
There is a switch on the back of the unit called SW3 with two options HG and HE. Now I'm not sure which it should be set at.
If the fan is placed in AUTO mode, SW3 defines the fan operation, as indicated below
HG states as follows:
1. When the thermostat is placed in cool mode, the fan works only when cooling is activated.
2. When the thermostat is placed in heat mode, the fan will be off.
HE states - In this setting, when the fan is placed in Auto mode, it works only when heating or cooling is activated.
Is this my issue? Do I maybe have this set wrong?
The furnace came on at first last night, but when we woke up this morning it was freezing in here. I thought it would kick in with the programs, but when I got home from work it was still freezing in here.
I'm in Edmonton and we just got hit with a massive storm, so I need heat! If anyone could help it would be greatly appreciated!
Holly
Holly1977 is offline   Reply With Quote
Old 11-08-2012, 07:57 AM   #2
Rewards Points: 1,528
Which setting is it at now?
From reading the instructions, I'd go with fan on auto and SW3 on HE.
bob22 is offline   Reply With Quote
Old 11-08-2012, 09:44 PM   #3
Thanks! We have it on that setting. I talked with a guy at Totem this afternoon and he figures that it just might not be compatible with the furnace. So I bought a Honeywell and will try that one here tonight. Fingers crossed, because coming home to 12C when it is -12C outside is not fun!
Old 11-08-2012, 10:22 PM   #4
Good luck! Let us know how it goes.
Old 11-18-2012, 09:11 PM   #5
Hi, girlfriend has the uberhaus th-3200, no manual. Came home from shopping, was 90 degrees F in the house. no idea how this thing works. only link i found for the manual online won't open. just need basic programming instructions. Any help will be appreciated...Thanks in advance....
SuperPHreak is offline   Reply With Quote
Old 11-19-2012, 07:15 AM   #6
try: http://www.google.com/url?sa=t&rct=j...ahJGESk3fqM8Dw
Uberhaus TH 4700 programmable thermostat Bisscheroux Electrical 1 10-14-2011 11:28 AM
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-14-2011 12:25 AM
Programmable thermostat and zone issues bawinnicki HVAC 7 01-10-2011 11:23 AM
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 05:38 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
