Typical/recommended MERV Ratings? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 10:34 AM   #1
typical/recommended MERV ratings?
Hi,
I posted previously asking about electronic air cleaners, and now have a related question RE air filtration. My HVAC installer has said that instead of the electronic air cleaner we could go with a MERV 9 4" filter setup, or if I wanted to go up to a MERV 13 4" filter setup. I understand what MERV ratings are and mean, but am wondering what is a typical rating used in a residential single family situation?
Is 13 overkill?
Thoughts?
Brian
b_corwin is offline   Reply With Quote
Old 09-23-2009, 11:02 AM   #2
sktn77a's Avatar
Rewards Points: 392
Depends on how small particles you want to filter. Personally, I use Merv8 in my house.
sktn77a is offline   Reply With Quote
Old 09-23-2009, 02:41 PM   #3
An old Tradesmen
Rewards Points: 8,238
Your A/C coil when in cooling mode and wet, is a MERV of 8.
So a filter of a MERV 8 is ok.
If you go to a MERV rating higher then 10, you want a 5" media filter, to help prevent loss of air flow.
Your contractor should check your systems static pressure before installing any media air filter.
Old 09-23-2009, 02:58 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 398
Beenthere is right, and we use MERV 10 5" filters on 90% of our jobs with no problems. Anything higher than a MERV 10 and I would want a ECM Variable speed fan not a basic PSC type. A ECM can produce a higher static pressure and maintain it without overheating the motor.
Pressure switch ratings gp_wa Electrical 6 08-31-2009 09:43 PM
Meter ratings Stubbie Electrical 3 04-02-2008 10:12 PM
What do you think about my house? 1 - 10 ratings joseph011 Off Topic 1 04-29-2006 01:34 AM
