| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Use a Miter Saw to Cut Crown Molding
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on a wall that takes a 45 degree turn. What we want to do is take the two pieces of crown and we will need to cut them both... Read More »
How to Cut Inline Joints in Crown Molding with a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cut an inline joint with a miter saw in crown molding. You might think that cutting your corners at the compound miter setting that you would... Read More »
Miter Saw Basics & Information
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating the basic functions of a miter saw. A miter saw allows you to make perfectly accurate straight miter and bevel cuts time and time again. A straight cut is a... Read More »
How to Cut Crown Molding on an Inside Corner with a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
How to Cut Crown Molding on an Outside Corner with a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
