Type I - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 01:42 PM   #1
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Type I
if you have the upon book 680 Type I certification can you buy freon ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 07-22-2013, 04:15 PM   #2
Yes, but I don't believe you're supposed to hook your gauges up to a system that holds more than five lb, so technically you have the right to work on stuff like refrigerators, freezers, dehumidifiers and window units.
taxmantoo is offline   Reply With Quote
The Following User Says Thank You to taxmantoo For This Useful Post:
Philly Master (07-26-2013)
Old 07-22-2013, 05:32 PM   #3
An old Tradesmen
Rewards Points: 7,808
Yes, you can buy refrigerants.
The Following User Says Thank You to beenthere For This Useful Post:
Old 07-22-2013, 10:55 PM   #4
Experienced HVAC Tech
HVAC1000's Avatar
Do u men 608 I've never heard of 680
HVAC1000 is offline   Reply With Quote
The Following User Says Thank You to HVAC1000 For This Useful Post:
Old 07-23-2013, 05:26 AM   #5
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
He's an electrician, he probably has article 680 of the NEC on the brain.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
Old 07-26-2013, 05:17 AM   #6
Rewards Points: 516
LMAO .... ok ok ...608 .......maybe thinking of adding HVAC
did auto a/c 40 years ago ....schooled and certified ( yea both ..certifiable ) ...
I have had the type I 608 since 2008 but never did anything with it..
have some oppurtunities with mini splits for small apts appox 500/600 sq, ft
looking at fujisu minisplits line..
AOU9RLFW
Old 07-26-2013, 06:55 AM   #7
An old Tradesmen
You need type II. Technically, a mini split is not a unitary unit. It is 2 separate parts. Unitary would be one part. EG: Window unit, PTAC, etc.
Old 07-26-2013, 09:33 AM   #8
And since your Type I was open book, you'll have to take the full Type II test with everything proctored.
Old 07-26-2013, 10:30 AM   #9
Rewards Points: 242
He will not need to take part I over. Show them your type I card and on the test is a spot you check that states you already have some parts. While your taking type II, might as well take type III also and get your universal.
It doesn't matter if he took the first part with another company. I'm also a proctor and give this test.
hvac instructor is offline   Reply With Quote
The Following User Says Thank You to hvac instructor For This Useful Post:
Old 07-26-2013, 11:50 AM   #10
Rewards Points: 516
Where is a good place to get schooled to take the test...
Old 07-26-2013, 11:56 AM   #11
Rewards Points: 242
most supply houses offer this. Prices will very. The school I taught at had a separate 2 day class for this. first Monday we went over the manual. 2nd Monday they took the test. If you only needed a retest and came in the day of the test, it was like only 50 bucks. also check with the community colleges if they have a program.
Old 07-26-2013, 12:20 PM   #12
Rewards Points: 516
That would be perfect.....
Old 07-26-2013, 12:25 PM   #13
Rewards Points: 242
just tell them your taking a retest so the correct box can be marked. this way you don't need to take the core and type I.
What type of cat5e cable type fastener? Ranger31 Electrical 8 06-29-2011 09:01 AM
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 03:35 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 03:27 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 12:30 AM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 01:08 PM
