Type Of Furnace Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 01:03 PM   #1
type of furnace filter
Hi, sorry for what is probably a stupid question.
I'm about to change the furnace filter in my new place. The previous owner happened to leave the manual for the furnace (Lennox AM30) and I had a quick look, and the manual says to always use the same type of filters. The current one is some kind of foam filter, never seen one like it before.
My question is, do I really have to use the same kind of filter, or can I go ahead and use, say, a 3M electrostatic of the same size?
jbat is offline   Reply With Quote
Old 05-02-2013, 01:28 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
you can use a paper throwaway type as long as it fits properly. more than likely a 16x25x1 or 20x25x1 depending on the unit. I would not use one that is rated higher than a MERV 8 as it may slow down the air too much and a electrostatic may do the same. go to HDepot they have true blue merv 7 or 8 generic filters. unfortunately that unit has had some issues and is sort of obsolete and you should get a experienced Lennox tech to check it out. it is pretty specific to Lennox so I would recommend their guys. don't ask what the issues are as I am not going to get into a long story.
The Following User Says Thank You to yuri For This Useful Post:
concretemasonry (05-02-2013)
Old 05-03-2013, 12:15 AM   #3
Experienced HVAC Tech
HVAC1000's Avatar
it sounds like it may be a washable filter. just take it out and wash it using your shower head dry and place back in slot
HVAC1000 is offline   Reply With Quote
old furnace with bizarre filter setup utek HVAC 2 10-14-2013 09:49 PM
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 02:14 PM
Going from 1 inch furnace filter to 5 inch furnace filter. BorgVilla HVAC 11 01-24-2011 05:17 PM
Heil Furnace - Filter adbolton HVAC 0 01-17-2011 10:23 AM
Milwaukee Thermoflo Furnace Filter? HELP! ur1ofus HVAC 1 12-02-2007 05:57 PM
