Type B Venting Question For Garage Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 02:32 PM   #1
Hi There,
Just installed a garage heater and now am working on the venting. Question I have is how do you vent out a wall at an angle?
The pipe has to go through a thimble which doesn't allow any angle through it. So wondering do I try to angle the thimble in the wall or if there is a better way.
I'm angling a little per specs (1/4" per foot) and even more because i'm too close to soffet where it comes out to make the 6 1/2" thimble hole.
Thanks,
Dustin
RoundPorch is offline   Reply With Quote
Old 01-02-2010, 02:43 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Put the thimble thru horizontal and buy a adjustable B vent elbow and adjust it any which way you want.
http://www.buyhardwaresupplies.com/h...15&StartRow=13
Old 01-02-2010, 06:42 PM   #3
An old Tradesmen
Rewards Points: 6,112
Is the heater rated for side wall venting.
Old 01-03-2010, 12:31 AM   #4
I'm pretty sure it is, shows that configuration in installation manual. It's a Beacon Morris 45,000 btu
I ended up cutting the hole in the wall and seems to work just fine. It's not such an extreme angle as I thought.
Old 01-03-2010, 12:34 AM   #5
An old Tradesmen
Ok.
Enjoy your heat.
Tags
gas vent type b
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
venting furnace & water heater tcoly General DIY Discussions 5 12-15-2009 05:41 PM
Water Heater Question cambece Electrical 5 08-31-2006 10:08 PM
venting question any pros? THEBIGPUNN Roofing/Siding 3 02-06-2006 09:19 PM
240/208 Heater wiring Question fburke Electrical 2 06-20-2005 01:09 PM
