Txv Therory Of Operation - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 10:11 AM   #1
Rewards Points: 392
Txv therory of operation
I'm trying to understand how a TXV works on a heat pump in both directions..
In heating mode High Pressure, High temperature vapor is going through the suction line to the indoor coil. The high temperature is on the bulb and the pressure sensor. And that is used to meter the flow out of the indoor coil.
In cooling mode Low Pressure, Low temperature vapor is going through the suction line out of the indoor coil. The low temperature and Low pressure is on the suction line and that is used to meter the flow into the indoor coil.
I can't seem to find any similar diagrams of a TXV valve that actually has a bulb and a connection to the larger "suction" line pressure sense connection. This pic appears to be a one-way TXV valve. Are the modern ones really two way and work in both directions? Or do they bypass in one direction.
Can someone explain how the TXV on my heatpump is able to work in both directions?
zootjeff is offline   Reply With Quote
Old 06-18-2010, 10:35 AM   #2
In a heat pump application they bypass in the reverse direction. Either by using an internal or external check valve.
hennyh is offline   Reply With Quote
Old 06-18-2010, 10:37 AM   #3
Rewards Points: 392
Then why are they required on a heat-pump to get the higher efficiency rating and why do they have two capillary connections instead of the one showed in the diagram I posted?
Old 06-18-2010, 01:35 PM   #4
An old Tradesmen
Rewards Points: 6,458
The TXV at the indoor coil. Only meters refrigerant in cooling mode. It is internally bypassed in heating mode.
Your outdoor unit has its own metering device for heating mode.
The Indoor TXV is only needed to get the higher SEER rating. Which is a cooling rating.
If by 2 capillaries. Your referring to the line that goes from the TXV body, to the vapor line. That is an external equalizer.
The Capillary at the top of the TXV is for the power head and sensing bulb. And has no opening into the TXV its self.
Operation Front Porch = Outdoor room Complete! Leah Frances Project Showcase 14 04-27-2011 10:14 PM
3 speed 3 ton Goodman handler operation. mr.coinring HVAC 5 05-29-2010 08:11 AM
Using A/C for first time after home reno. Not sure if this is normal operation. the punisher HVAC 7 05-25-2010 07:42 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 06:01 PM
Sequence of operation hot water heater pomelo Plumbing 5 01-25-2010 12:29 PM
