TXV Needed For New Install? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 10:42 PM   #1
TXV needed for new install?
I'm about to have a goodman 3ton 13 seer condenser and coil installed.
Goodman sells a TXV as an optional upgrade for this coil -- is it worth paying extra for one?
walkman is offline   Reply With Quote
Old 04-26-2011, 11:16 PM   #2
TXV will keep the temperature more stable but can break.
I suggest you spring for the extra money and get the SSR seer 14 goodman. Has many upgrades, pressure switches, sound blanket over the compressor. Much quieter.
DIY_HVAC is offline   Reply With Quote
Decking Issue after new roof install CrankyDragon Roofing/Siding 12 07-04-2011 10:26 AM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 09:02 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
