TXV Is KING! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 04:36 PM   #1
TXV is KING!
Just want to let people here know that if you have an older system without a TXV you should seriously consider retrofitting. I am surprised that anyone would not see this to be true. I formerly had a fixed orifice metering the refrigerant and the system suffered miserably. I posted videos (look my name up and prior posts) and never did I hear that the TXV would help. I was trying to convince some here after researching endlessy that the information seemed to be pointing to a TXV. After installing one the frosting up of the suction line ceased and the compressor hums. No more temperature drops. I had 100 degree output on a 30 degree morning! So let me be the one to tell you, go TXV!
Here is a link to show you what I mean, goes for Heat Pumps as well. Don't over think it, you will not regret installing one.
http://www.pge.com/includes/docs/pdf...3txvtechv5.pdf
carlb7 is offline   Reply With Quote
King valve as expansion valve... Danman5000 HVAC 14 09-18-2011 11:18 AM
Greetings from King of Prussia (PA)! JohnnyD44 Introductions 2 03-11-2011 07:23 PM
steel plate instead of king jacks? hohadcr Carpentry 15 09-10-2010 04:59 PM
Different configurations of King Studs. Shea_Close Building & Construction 7 06-08-2010 08:37 PM
load bearing wall under king post trusses jimby Carpentry 5 01-02-2009 05:15 PM
