Old 09-17-2007, 12:57 PM   #1
TXV or fixed
What is an easy way to tell if your AC has a TXV or a fixed orifice? That is without cutting into sheet metal to look at the evaporator coil. I most times just go by the amount of time it takes for the pressures to equalize but I'm sure there is a better/easier way.
cjett is offline   Reply With Quote
Old 09-29-2007, 04:38 PM   #2
TXV or fixed
There is no other way to be sure other than to see the metering device (txv or piston)
abhac is offline   Reply With Quote
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
Skylight leaking advice needed!Thanks Beeper29x Roofing 12 10-04-2005 09:53 PM
NO bath water running!!! rath Plumbing 1 09-09-2005 01:13 PM
