Two Wire Thermostat (heat Only) - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 07:42 AM   #1
Joe F's Avatar
Rewards Points: 294
Two wire thermostat (heat only)
I'm rewiring my heating zones with a Taco zone controller. The zone controller connections are not labeled R or W (TT). The thermostat has R & W. I assume it doesn't matter since it's 24vac. (i.e W & R are interchangable)
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-14-2009, 11:18 AM   #2
An old Tradesmen
Rewards Points: 7,342
Yes they are.
Old 10-14-2009, 11:45 AM   #3
Joe F's Avatar
Rewards Points: 294
Thanks a lot beenthere!!! I'm just finishing up putting my system back together after replumbing and rezoniong (you helped me redesign it a few months ago). Filled the boiler yesterday and lit off 3 zones last night. Still need to run the t-stat wires for the 2 new zones. Couldn't have done it without you.
Old 10-14-2009, 11:50 AM   #4
An old Tradesmen
Your welcome.
Glad to hear everything is going well.
new thermostat fan motor blowing in heat mode Taz38 HVAC 2 02-15-2009 10:18 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 07:14 AM
radiant floor heat thermostat kornbln Electrical 5 03-27-2008 12:45 PM
