Two Tstats One Zone System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 12:16 PM   #1
Two tstats one zone system
Am looking for advice on adding a second thermostat to my system. I currently have a two story home, with one zone for the whole house. My question is can I add a thermostat upstairs (currently active tstat is downstairs) while keeping the one downstairs active.
My thinking is if tstaA is off, and tsatB is on then the system should work as normal. Obviously if both are on then the system wouldn't work normally, and if they were both off then the system wouldnt be on anyways.
Does this make sense and will it work for the mean time until I can save to have the second zone installed?
Kriggio824 is offline   Reply With Quote
Old 10-17-2011, 12:54 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,842
If the upstairs is warmer or colder than downstairs, you are better to find out why the system is not working as it should, or why the house is not insulated properly. As for using a remote thermostat, they are better for when you zone a system, due to it is either going to cause the lower floor to be either too warm or too cold. Also, if you do not have cold air returns in the rooms upstairs, not including baths, that can cause hot and cold zones.
What is the temp difference between floors, what is the air temp at the furnace/air handler, at the register on the first floor, register at the second floor, cold air return on the first floor, and cold air return on the second floor.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
New tstats: residential Carrier Weathermaker II Two-Zone Comfort Zoning System JeanThomas HVAC 2 03-24-2011 10:22 PM
Need to bleed a hot water baseboard heating system Brewmaster HVAC 4 02-17-2011 08:04 PM
Bleeding Multi Zone Forced Hot Water System JJL Jr HVAC 1 02-13-2011 03:49 PM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
Adding new zone makapacs HVAC 0 11-26-2009 01:35 PM
