Two Stage Or Not? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 03:32 AM   #1
Two stage or not?
I just had a Lennox gv61MVP installed with a lennox c5000 tstat. All the settings are set for 2 stage but how can I tell if stage 1 actually gets used?
NJ-Resident is offline   Reply With Quote
Old 02-23-2011, 04:59 AM   #2
An old Tradesmen
Rewards Points: 6,860
Wait for it to start up, Then after the fan has been running for 5 minutes, see how much/hard the air is blowing out of a register, then turn the stat up 5 more degrees. You should have more air blowing out within a minute or 2.
Is there a reason I shouldn't disable second stage heat? zootjeff HVAC 18 01-02-2011 02:23 PM
2nd stage, please veesubotee HVAC 27 03-15-2010 06:26 AM
Multi stage heat pump thermostat marriedmanw HVAC 2 02-28-2010 04:12 PM
2 stage heating and thermostat settings BlueBSH HVAC 4 12-17-2009 08:07 AM
How to confirm 2nd stage burner working? mirob HVAC 49 12-29-2008 06:11 PM
