-   -   Two stage heating thermostat recommendation (http://www.diychatroom.com/f17/two-stage-heating-thermostat-recommendation-118273/)
stubborn1 09-25-2011 02:29 PM
I just installed a new 80k btu York high efficiency two stage gas furnance in our vacation property. I picked up a basic manual two stage stat from the orange box store, but I'm not happy with the performance. It's a no name Filtrete brand stat and I should have known better than to buy something cheap. The thermostat will call for heat and then kick out 10-15 seconds later before the blower even kicks in. This happens for 2-3 times before the furnace will run for a cycle.
Anyway, I don't need any fancy programming capabilities since this will be installed in a vacation property. I'm looking for something simple and reliable, but with two stage capability. Any recommendations?
gregzoll 09-25-2011 03:57 PM
Here is a search for Honeywell thermostats that are non-programmable multi stage: http://search.yahoo.com/search;_ylt=...te=&fr2=sp-top If you want something that you can access or monitor while away, you could look at the 3m Filtrete CT-50, which is manufactured by Radiothermostat.com. It has a Simple screen, which allows it to work like a non-programmable.
